Inventor General Discussion
*Pro
jletcher
Message 11 of 19 (282 Views)
Re: Shrinkwrapping Assemblies
07-10-2012 08:06 AM in reply to: PACDrafting
May I ask why you shrinkwrap? I have found no use for it and would like to see why others do.
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
PACDrafting
Message 12 of 19 (267 Views)
07-10-2012 07:15 PM in reply to: jletcher
Good for Large Assembly modelling
*Pro
jletcher
Message 13 of 19 (242 Views)
07-11-2012 11:31 AM in reply to: PACDrafting
So how many parts you talking about. I have a 263,000 parts in assemblies and subs never had to shrinkwrap..
James Letcher
PACDrafting
Message 14 of 19 (235 Views)
07-11-2012 02:04 PM in reply to: PACDrafting
Ok.
Do you think your working efficiently in terms of opening speeds? And in terms of drawing output.
Or do you swear and curse continuously?
Active Contributor
hunt
Message 15 of 19 (233 Views)
07-11-2012 02:12 PM in reply to: jletcher
I've used it to send a model of an assembly to a customer without sharing all of the components as well.
Valued Contributor
streharg
Message 16 of 19 (201 Views)
09-24-2012 05:02 AM in reply to: jletcher
I would really like to see your PC specs, and your working speed.
For presentation of large projects (~1.000.000 parts), we have to shrinkwrap basically everything.
For normal work, assemblies up to 50.000 parts (normally couple of 1000) work normally without SW.
Factory design suite 2013 premium
Some old workstation ...
Fancy HP LCD
:smileyhappy:
*Pro
jletcher
Message 17 of 19 (164 Views)
09-25-2012 07:02 AM in reply to: hunt
I use derived assembly for that.
James Letcher
*Pro
jletcher
Message 18 of 19 (163 Views)
09-25-2012 07:08 AM in reply to: streharg
At that time I made it was
4 gig ram with 3 gig switch
can't remember the video card quadra with 256 memory
Dual zoen processor I think it was 2.34 GHz
James Letcher
Valued Contributor
streharg
Message 19 of 19 (143 Views)
09-25-2012 11:59 PM in reply to: jletcher
That looks almost unreal! :smileyhappy:
I have old workstation (8 gb of ram, quadro 256 mb of ram, xeon ....) and have problems with assemblies larger than 10,000 parts. So, if I want to do anything bigger, I have to shrinkwrap subassemblies. And best performance i get now is with simplify (FDS 2013) and shrinkwrap (surface), with broken link to original (which are on network, and i prefer to do big things local on other mashine with ssd - it's just faster).
But it's true, i'm still learning things.
Thnx!
Greg
Fancy HP LCD
:smileyhappy:
