Inventor General Discussion
Member
alexpinedo5052
Message 1 of 3 (205 Views)
shrinkwrap problem
205 Views, 2 Replies
11-19-2012 02:06 AM
From an assembly I created a shrinkwrap part. In the options window, I modified the range to plug the holes (default range is 10-999999 mm). The problem is that every time I update the shrinkwrap part, the range changes to the default values.
I am using Inventor 2013 and this problem didn't happen in a previuos versions.
Any solution?
Thanks.
JDMather
Message 2 of 3 (187 Views)
Re: shrinkwrap problem
11-19-2012 10:23 AM in reply to: alexpinedo5052
Any solution?
Thanks.
I haven't checked to see if the problem can be reproduced in SP1.1, but that is the obvious first question - are you on the latest Service Pack?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
alexpinedo5052
Message 3 of 3 (167 Views)
11-20-2012 12:35 AM in reply to: alexpinedo5052
yes I am on SP1.1
Thanks.
