Inventor Forum
Shrinkwrap for Inventor 2010
1 REPLY 1
PEMBERTONA
210 Views, 1 Reply
I am using Inventor 2010 and having trouble with shrinkwrapping an assembly. During the shrinkwrap settings for a solid shrinkwrap part, the part actually gets solid, but when I pick OK, the interior of the part which was showing solid during the hole range settings, goes away. I am saving the assembly as an .ipt first then the shrinkwrap settings I am using are as follows:
Style: SOLID
Simplification: REMOVE GEOMETRY BY VISIBILITY is checked, which picks Whole Parts Only and visibility is 0.
Ignore Surface Features For Visibility Detection: is unchecked
Remove Parts By Size: is unchecked
Hole Patching is 8 to 100, which works for this part.
Include Other Objects: everything in this area is unchecked.
Break Link: is unchecked.
Reduce Memory Mode: is checked.
Any ideas of what is happening?
Alvin Pemberton
1 REPLY 1
johnsonshiue
in reply to: PEMBERTONA
Hi! It sounds like you don't want internal components to be removed, right? If yes, please uncheck the following option.
"Simplification: REMOVE GEOMETRY BY VISIBILITY is checked, which picks Whole Parts Only and visibility is 0."
Thanks!
Software Test Engineer
