Inventor Forum
Shrinkwrap CENTER OF GRAVITY
3 REPLIES 3
slalwani
408 Views, 3 Replies
It has been noticed by our department via model trials that shrinkwrap's Center of Gravity (CoG) differs from actual model CoG even though the solid feature is chosen when creating a shrinkwrap to maintain proper volume with proper weights. We create custom oilwell trucks and weight analysis is a big part of our design. Now i cannot put in full assemblies without shrinkwrap (slows down a lot and very cumbersome). Shrinkwrap is the only way my overall assembly seems workable. I was having my department implement model's weight analysis which inventor let me down. Is there any explanation to that?
Summit
16GB Ram
3.8Ghz O/C Processor Intel Core 7
WinXP
IV2010
3 REPLIES 3
slalwani
in reply to: slalwani
Sorry, that should be WIN 7 not XP.
Summit
cwhetten
Shrinkwrap creates a single part file that is "derived" from an assembly file.  This single part file can only be of one material and, therefore, one uniform density.  If your assembly consists of components of various materials and, therefore, various densities, then there will be a discrepancy in the location of the COG between the full assembly and the shrinkwrapped part.
Because the idea of a shrinkwrap is to create a single part, there is no way of getting around this.  Use a different approach than shrinkwrap if you need accurate COG locations.
-cwhetten
cwhetten
Another issue with shrinkwrap is that, depending on your settings, it can fill in cavities in your model.  If these cavities are large enough, this will throw off the volume and mass of a model, and therefore yield a significantly bogus COG location.
-cwhetten
