Inventor Forum
showing section view in base viw
2 REPLIES 2
admin
270 Views, 2 Replies
Dear sir,
plz suggest me the procedure how to show section view in base view with out projection the component.
regards
RS MODI
2 REPLIES 2
nannerdw
in reply to: admin
Select the view on your drawing, and click "Create Sketch" from the "Place Views" tab.  (Make sure your view is selected before you create the sketch, so the sketch will be contained within the view).
Now draw a rectangle around the outisde of the whole part.  Anything within the closed area will be sectioned.
Click "Finish Sketch."
Click "Break Out" on the "Place Views" tab, and select your view.
For the depth, I'd probably select "From Point, 0.000," and pick a point on the outer edge of one of the cylindrical features, since that point will be located at the right depth for the section to go to the exact center of the part.
Yong.Jing
in reply to: nannerdw
There is another process to get what you want.
1, create base view, and move it out of the drawing area
2, create section view from base view
Then only the section view is in the drawing area and printable.
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
