At one time I managed to divine a way of showing parts in an assembly drawing in phantom. This is characterized by the icon for the part in the browser changing to green colour. Being elderly, I have forgotten how I managed to do this. Could anyone enlighten me on the procedure for doing this ?
Thank you in advance
Solved by cwhetten. Go to Solution.
Solved by PaulMunford. Go to Solution.
Welcome to the forum.
In your browser under the view that you want the component shown in phantom tree out the view until you see the component. Then right click on the part and select properties.
Then in the next dialog window you will see where you can change the line type.
or are you talking about setting a part to "reference" which will cause it to not show in the parts list and also being shown as hidden lines in a drawing automatically.
What is the intent or reason for showing these parts like this?
Do you want these parts shown in "hidden" lines just for visual purposes in a single view?
Do these parts need to be included in the bill of materials/parts list for that assembly?
Are these "reference" parts like an assembly/welding fixture or something?
Knowing the intended reason for wanting this will help us to tell you how it "should" be done and why.
I think maybe you aren't talking about an actual drawing (.idw file), but an assembly (.iam file). In this case, I think what you are looking for is Enable/Disable. Right-click a component and uncheck Enable. This will "ghost out" the part, making it mostly transparent but still visible. This will also make the icon turn green, like you said.
To turn it back on, just right-click it and check Enable (you will have to do this in the tree/browser, since one of the effects of disabling a part is that it is no longer selectable in the graphics window).
yeah a "drawing" (idw file) is a 2D representation of a part (ipt file) or assembly file (iam file).
"phantom" is routinely used to describe a "non-stocking/built on-the-fly" subassembly in which all the components in that subassembly are pushed up into the upper level assembly bill of materials.
