Inventor General Discussion
Distinguished Contributor
24 Kudos
Post 1 of 10
Show Mirror Image
994 Views, 9 Replies
08-09-2011 03:43 AM
I design a lot of doors and every once in awhile I need to design a quick one off of an already design opposite hand. There seems to be plenty of room on the form for an extra option check box.. :smileyhappy: Any Autodesk programmers looking for extra work?? Just a thought...Mirror.PNG
Employee
194 Kudos
Post 2 of 10
Re: Show Mirror Image
08-09-2011 09:38 AM in reply to: waynefisher
Hi! This is a very interesting request to Inventor Drawing. Inventor Drawing is another view of physical geometry on a part or an assembly. To support full associativity, it does not display something does not exist on the physical model.
Did you try mirroring the part or mirroring the assembly and then creating the views?
Thanks!
Senior Principal SQA Engineer, Inventor
Mechanical Design
24 Kudos
Post 3 of 10
08-09-2011 09:50 AM in reply to: johnsonshiue
Yes that is how I have to do it now. Unfortunately it is very time consuming to redo all the layout details. If I can mirror the parts and assemblies, why can I not mirror the layouts? If I am in a real hurry, I export the idw to dwg and mirror them in Autocad. Is there a better way to handle this in Inventor?
Employee
194 Kudos
Post 4 of 10
08-09-2011 10:18 AM in reply to: waynefisher
If associativity is not a concern, for speed actually you can try the following workflow without mirroring the whole assembly. But. you still need to mirror the geometry regardless.
Here is what I would do. You can simply derive the assembly -> check Mirror option and pick a mirror plane from origin planes and select either Composite option or Separate Solids option. Then create a drawing view of the mirrored derive assembly part.
Another way to do it is by purely image mirroring by a image processing software.
Thanks!
Mechanical Design
Distinguished Mentor
139 Kudos
Post 5 of 10
08-09-2011 01:34 PM in reply to: johnsonshiue
Could you simply open in Acad and mirror there?
Product Support
47 Kudos
Post 6 of 10
08-09-2011 04:44 PM in reply to: rdyson
Ray, it looks like he wants to accomplish this in Inventor.
If the view of the door is the front view, why not create a back view of the door? Shouldn't that give the mirror image?
Of course you will have to transport the dimensions one by one from the front view view to the back view (with the "Move dimension" command")  and you probably need to change some of the hidden lines to continuous lines as well with the "Select as edges" functionality but at least it allows you to stay in a single environment to produce a drawing of the mirror.
Bob
New Member
0 Kudos
Post 7 of 10
04-16-2013 07:56 AM in reply to: johnsonshiue
This feature could be implemented exactly as proposed while still maintaining associativity.  We, the users, don't care how hard it would be to program; it would be an AWESOME feature!  Why not mirror the associativity along with the lines?!?  Mirror the view, smarts and all!
New Member
0 Kudos
Post 8 of 10
04-16-2013 08:07 AM in reply to: waynefisher
This would be a great feature!  I work at a machine shop, and we often produce opposite-hand parts.  It is a major PITA to mirror assemblies; it often (usually) doesn't work right, and it creates a hundred new part files, which is a mess for our procedures (these mirrored part files are often bi-axially symmetrical anyway, so the mirrored version is really the same part!).
1,704 Kudos
Post 9 of 10
04-16-2013 08:24 AM in reply to: joal_o
Hi joal_o,
It looks like the original conversation in this thread happened before the Inventor Idea Station was around, but at this point you might want to share your ideas about how to improve Inventor with the Development Team:
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
52 Kudos
Post 10 of 10
04-16-2013 11:07 AM in reply to: waynefisher
or do like we do and just show one.
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
Intel Dual Xeon E31225 @ 3.1 GHz CPU
16 GB RAM
NVIDIA Quadro 600 GPU
Windows 7 - 64 Bit
