I have an IDW and i want to show some hidden lines, i can select all but i only want to select a few. Is there an easy way to do this without right clicking and hiding most of the hidden lines.
Appreciate any help
Solved by mdavis22569. Go to Solution.
If I understand correctly ...you're doing the turning off in the view ....
Go to the browser on the left ... pick the IAM , expand it, pick all the items you want hidden ...RMB (yes you have it here too) ... but at least you can pick everything you want to turn off all at once.
