Inventor General Discussion
1 Kudo
Post 1 of 3
Accepted Solution
Show Flat Pattern Problem
454 Views, 2 Replies
08-26-2012 04:03 PM
Hi All. It's my first time using sheet metal in a drawing and I can't figure out how to show flat pattern in the drawing. When I insert the base view into my drawing, the bottom to "Sheet Metal View" to "Flat Pattern" is shown, but it's ghosted out so I can't select it. Is there something I have to do in the part drawing in order to activate this feature? Thanks in advance for any replies.
You have to have a Flat Pattern node in the browser of the part file.
Attach your file here if you can't figure it out.
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0126-Tutorial126/0127-Inventor127/0663-Sheet_Me663
*Expert Elite*
2,120 Kudos
Post 2 of 3
Re: Show Flat Pattern Problem
08-26-2012 04:42 PM in reply to: guitarsoulja
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0126-Tutorial126/0127-Inventor127/0663-Sheet_Me6...
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
1 Kudo
Post 3 of 3
08-26-2012 06:06 PM in reply to: JDMather
Huge thanks for the direction to the manual. Read the file and it exaplains everything. I'm terrible with finding things in the manual. Thanks again. - AJ
Post to the Community
New Post
