Is there any to make the icons that show what constraints are on an object larger, or more well defined at least? They are so small and pixelated sometimes that i cannot disern what they are trying to tell me.
Solved by Curtis_Waguespack. Go to Solution.
Solved by JDMather. Go to Solution.
Tools>Application Options>General tab increase Annotation Scale.
that changes the size of the UCS, and the dimensions (thanks that is a help), but the icons stay the same size. I should say i am using Inventor 2014, incase it only does that in 2015.
Hi TKey_Luttrell,
Look at the Tools tab > Application Options button > Sketch tab > Constraint and DOF symbol scale setting:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-E1C6B27E-9BA9-4B4F-9B71-7777833745A3
I hope this helps.
Curtis
Is there a way to do this in 2016? Dimensions and constraints are very tiny.
This has been rolled into Annotation Scale on the General tab now it seems. So refer to the first response.
I have now marked the post as an answer.
To those who might be confused, the larger answer applies fo INV 2014, the shorter answer applies to INV 2016
