I assume you mean you just want to shorten 1 extension line, instead of both
of them. If you want to do both then just create another style, but if you
only want to change 1, then you could do manually. You could create a sketch
on the drawing, and draw a line where you want the dim to snap to, then
dimension to this line. Then set the properties for the line you created so
that it's either white, or set it on a layer that doesn’t print.
"L.Mah" wrote in message news:5991952@discussion.autodesk.com...
> as you all know, sometimes there are lots of dims and the lines get too
> busy. you just don't need the entire extension line.
> i don't think inventor can do this yet. unless you manually change it in
> styles
