Whenever I go to do a "Save As" or an "Open" (not from Vault), over on the left it has a gray area that says "Workspace", "Libraries" and under "Libraries" says "Content Center Files".
How do I edit this to add some standard network locations where we often save things? I often "Save Copy As" to save DXFs into another folder, completely separate from the project file, so sheet metal can get to the flat patterns to burn them out. It would be nice to have a shortcut to this location.
Thanks!
There's no way to add a custom shortcut on the location panel.
You, however, can add a Libraries path in your project settings.
Anything you save there cannot be edited (other than overwrite/resave),
but I think it should not be a problem in the workflow you described.
Hope this helps,
-Sami
