Hi all,one of our customers has submitted a spec for operating shock and vibration per mil-std 167 with certain values.
I have Inventor 2014 Pro. Can the stress analysis perform what I need to simulate? Do I need another program?
I will sit down with the engineer in my dept tomorrow, I am a designer and never worked with this extension of Inventor.
operating shock 100 g, 6mS half sine one shock input in each of three perpendicualr axes, for a total of six shock inputs.
Just need to know basically if what I have as far as software can be useful.
Solved by WILLIAMF. Go to Solution.
You need another software package to do this. Inventor can do quasi-static stress analysis and modal analysis; you can get the steady-state loads and the resonances but you need the dynamic solution. The industy standard for what you want is LS-DYNA. Other major finite element packages (e.g., ANSYS) can do this, too.
Hi!
If you want to use Autodesk Software, you can also use "Mechanical Simulation" for non-linear analysis.
I see there is a dynamic simulation tab in environments that allows the settings to be saved to ansys as atext file or AIP sress analysis.
Maybe this can be useful. I never used it so I will need to learn.
Hi, I don't believe the dynamic simulation can do the kind of analysis you need. I believe its main purpose is to analyze machines; shock is really a class in itself. Just to experiment I made a basic assembly of a lead ball hovering over a steel plate. Going into the dynamic simulation environment gives you the ability to drop it with gravity but I cannot find a way to prescribe velocity or acceleration. I don't know if you can parameterize the force to be proportional with position and get the vel. or accel. that way. Instead, I RMB'd on external loads / gravity --> "define gravity" made it 100g's downward. This is still a far cry from what you need to do to meet the letter of the spec. The internal FEA environment can only do static stresses and modal.
I would suggest you contract this out if you are new to this and are obligated to deliver the analysis.
Thanks for doing all of that work. I appreciate your time and energy and will heed your advise. From what I have been doing it appears you are correct with only static abilities.
I am just stating that the users posts above are correct. You would need to look at the simulation software. See link for some possible information.
Don
ok thanks
We are looking into it
I think you need to go with Response spectrum analysis.
If your equipment is naval use then you may us DDAM analysis which has in built shock spectra as per us military standards.
In order to do any of those analysis, you must need to do natural frequency (Model) analysis.
You can go with Autodesk simulation mechanical package with has all required modules for such a analysis.
Regards and All the best,
Vikas Patel
(MSc. Product developer)
This thread is 2 yrs old.
I suspect their lead time was a bit less than 2 yrs.
The CADWhisperer YouTube Channel
