Yes, after years of trying to work around the bugs that adesk refuses to fix I dumped inventor from my ship design business and went back to 2D, I dont even bother with Rhino, I just use Maxsurf, workshop and detail in 2D . Inventor has 90% of what we need but the 10% that's missing is the most important 10% and makes the drawing process too slow. You can model ships in Inv, but it's a very slow process. Same can be said for all the other mid range CAD, they dont have the tools we need.
Shipconstructors marketing angle is spend more time in design to save $$ in production. A program that slows the design process and hence makes it more expensive doesnt interest me either.
All of above in relation to metal boats, fibreglass would be a bit better.
I think it is a little bit dependent on the size of vessel you are building & your cad package budget.
For small vessels you could use rhino for modelling, basic hydrostatics & detailing (could use autocad lt for detailing).
As the vessel size gets bigger it's worth while investing in better cad packages.
Inventor could be a good option after the shell/hull has been defined (there are a number of packages out there that can assit in hull design).
The hull could then be imported into Inventor for structure, MEP & fitout.
Cian
@CianG wrote:Inventor could be a good option after the shell/hull has been defined (there are a number of packages out there that can assit in hull design).
Cian
In theory yes, in reality the bugs make this a very slow and time consuming task. So bad that one on my naval architects quit because of the daily frustration of parts not updating, and it was only 25m long. If they fixed the bugs it would be ok, but an adesk senior person told me they wont be fixed because not enough people complain about them. Not so bad for small boats up to 10m but then they can be done in Rhino which is a fraction of the cost. Inv is not a ship design tool, and attempting to use it in ship design has been a disaster.
Ship Constructor exists because mid range cad cant do the job.
They are not marine specific, just happen to be critical to a ship design workflow. They have all been reported, acknowledged and are at the bottom of the priority list.
Ive used Inventor extensivly on ship design. generally surface models are more useful because you can integrate them into other software like femap and sesam genie. Also surface models produce nice single line drawings for autocad export...
it takes lots of planning but with powerful techniques like skeletal modelling and a bit of ilogic ship design with inventor is not just possible it is very good, a lot will depend on the skillset of the user
Did you create drawings for shipyard production and flatten parts for NC cutting?
I would be very interested to know how you create the frame stiffener punchouts and clean up the slivers for cutting, how you flatten your curved shell plates and get frame station marking lines on them, how you flatten your hull stiffeners for cutting, how you model your frame rider bars, how you model and mate tripping brackets in the bow, how you add limber holes to stiffeners and once done how your model behaves when you change the hull shape. It can all be done, I can just do it much faster in 2D.
As for user experience, the best support people from my VAR could not find a suitable work flow that dealt with the bugs which is why I ended up talking to adesk direct, and they had no idea either. It also depends on what type of ship structure you design, and how much production detail you include, and of course how much time and budget you have for the project.
frame stiffener punchouts, each stiffener had the punchout surface extruded with the stiffener and all of them turned on or off with a parameter and ilogic
no slithers on the punchouts because they petrude thru the shell so cut all the frame to the shell extents. offsetting frame plate thickness was problematic because femap uses the mid plane of the frame but we model frame correct, offsetting fwd or aft depending on position to midships and just accept this for analysis
we didnt do the shell expansion and dont think it would be possible in inventor...
We did basic design, up to class approval on some very simple jackup ships, basically big boxes that only had shape in the bow and stern. Because the shapes were so simple inventor is able to model the hull and this hull is derived into almost every part so as the hull shape changes our structure changes to suit. We also relied heavily on excel for parameter input and of course autocad for the 2d drawings
Autocad has come a long way, some ilogic on the drawing exports from inventor and a few autocad scripts made it all quite streamlined. Because inventor and autocad are generic drawing and modelling software we customized them quite heavily to achieve what we required required
