Hi Guys,
Trying to shell this lofted shape however it freezes and crashes after a while.
for some reason i think its loft 5 which is messing things up.
Trying the shell it from point A, (6mm thickness)
Any ideas?
Solved by WHolzwarth. Go to Solution.
Nice shape, but no easy task for shelling.
See my result. EOP needs to be moved down.
Walter
Walter Holzwarth
Here's another, more straightforward, solution.
Interesting to see, that it's more than double filesize with EOP down than the first one.
And funny results can be seen, if Delete face with heal is used alternatively for the model state after Split1
Walter Holzwarth
Yeah thats interesting about the EOP down,
Thank you very much for the help Walter
Hi! Here is another approach using full round fillet instead of lofts. The part can be shelled fine. It does seem like the original Loft5 and Loft6 are making things unnecessarily more complicated. The behavior is not right though. I will forward it to development for further review.
Many thanks!
Thanks back for your Kudos.
Perhaps we can see improvements in near future.
Walter
Walter Holzwarth
