Can the underside of the 5 spokes be shelled out 2mm including having an opening to the outer rim.Maybe the Outer rim could have been shelled 2mm as well but the REvolution did the job.If the outer rim could have been shelled how would this be done or is the revolution the better option
cheers
IJC
Solved by mcgyvr. Go to Solution.
pull EOP (end of part) up over the revolution.. Shell to 2mm.. pull EOP back down.
Is that what you wanted?
I just noticed, that you're on 2013. Pardon.
If needed, I can do this task another time with 2013. It's not very much effort, after knowing how to do.
But I'm breaking my brain for ways to a mold layout for this part. See more in a new thread.
Walter
Walter Holzwarth
My "solution".
