Inventor Forum
Sheetmetal Rip
8 REPLIES 8
Message 1 of 9
302 Views, 8 Replies
Sheetmetal Rip
Hi all
I'm sure someone posted a method of doing what I want, but I can't find it
in older messages.
What I need is a flange as in the darker part, with no rip relief as I'm
getting in the lighter one.
I created the darker one by offsetting a plane then creating a flat wall and
finally a bend.
I'm sure someone posted the sheetmetal settings that did this with a normal
flange feature.
Anyone?.....
Rui
8 REPLIES 8
Message 2 of 9
Crank up the Minimum Remnant to some big number like 100.
"RuiF" wrote in message
news:5CA8ABB21F526B64332EFCCB4DD0FE1F@in.WebX.maYIadrTaRb...
> Hi all
> in older messages.
and
> finally a bend.
normal
> flange feature.
> Anyone?.....
> Thanks
> Rui
Message 3 of 9
Does nothing.
Anything else I can try?
Rui
"mvier40" wrote in message
news:EAF2AF3691A8690B4072388AE67E9141@in.WebX.maYIadrTaRb...
> > Hi all
it
> > in older messages.
> and
> > finally a bend.
> normal
> > flange feature.
> > Anyone?.....
> > Thanks
> > Rui
Message 4 of 9
Can you post the file so I can fiddle with it? That's usually the only way I
can fix things.
news:EF79A84E450EAB613017E0C413F8664E@in.WebX.maYIadrTaRb...
> Does nothing.
> Rui
> > > Hi all
find
> it
> > > in older messages.
I'm
wall
> > and
> > > finally a bend.
> > normal
> > > flange feature.
> > > Anyone?.....
> > > Thanks
> > > Rui
Message 5 of 9
Simple version in iCF.
Rui
news:301D1A953D4EBEADEAB92C8EDE08BD5E@in.WebX.maYIadrTaRb...
I
> can fix things.
> > Does nothing.
> > Rui
> > > > Hi all
> find
> > it
> > > > in older messages.
> I'm
> wall
> > > and
> > > > finally a bend.
> > > normal
> > > > flange feature.
> > > > Anyone?.....
> > > > Thanks
> > > > Rui
Message 6 of 9
Sorry to not get back - just got in.
The way that you've curved off the edge like that and then put in a flange,
I don't think Inventor is gonna be able to figure out how to trim that back.
I think it's too much to ask a software package to decide how to transition
the remnant removal from a curved edge. If it was just going off to a
straight lined edge, I'd say you had a chance of removing the excess. I'm
not real good at this Inventor, maybe some of the pros would have a word or
two for this special situation. Good luck! Sorry I couldn't help on this
one.
news:AEB9E48C3B2CF577A8CD6909AC4B25D6@in.WebX.maYIadrTaRb...
> Rui
way
> I
> > can fix things.
> > > Does nothing.
> > > Rui
> > > > > Hi all
> > find
> > > it
> > > > > in older messages.
as
> > I'm
flat
> > wall
> > > > and
> > > > > finally a bend.
a
> > > > normal
> > > > > flange feature.
> > > > > Anyone?.....
> > > > > Thanks
> > > > > Rui
Message 7 of 9
I put a couple of files in iCF; 2 files; one with a small remnant left. Not
sure it's what you're after, but I think it could be made okay.
~Larry
> Hi all
> in older messages.
and
> finally a bend.
normal
> flange feature.
> Anyone?.....
> Thanks
> Rui
Message 8 of 9
Larry, looks like you accomplished this feat in both instances by setting
the bend radius to a very small number. I have contemplated the same thing
to achieve a desired result as well, but rejected it because I feared it
would result in an inaccurate flat pattern. Is this the case do you know?
Have a nice day
"Larry Caldwell" wrote in message
news:51880AFD8FA9F693CFE73D8B3EE59BDD@in.WebX.maYIadrTaRb...
Not
> ~Larry
> > Hi all
it
> > in older messages.
> and
> > finally a bend.
> normal
> > flange feature.
> > Anyone?.....
> > Thanks
> > Rui
Message 9 of 9
Well ... no real straight forward answer to that. To get it where it comes
out right it depends on the brake/whatever it's going to be made on;
different machines, different dies, etc, but if you know some of that or can
run a test, you can adjust the K-Factor and other settings to get the size
flat where it will come out correctly.
~Larry
news:DBFB69268CEA7DB0B1374DF52E748293@in.WebX.maYIadrTaRb...
> Have a nice day
> Not
> > ~Larry
> > > Hi all
find
> it
> > > in older messages.
I'm
wall
> > and
> > > finally a bend.
> > normal
> > > flange feature.
> > > Anyone?.....
> > > Thanks
> > > Rui
