Well ... no real straight forward answer to that. To get it where it comes
out right it depends on the brake/whatever it's going to be made on;
different machines, different dies, etc, but if you know some of that or can
run a test, you can adjust the K-Factor and other settings to get the size
flat where it will come out correctly.
~Larry
"mvier40" wrote in message
news:DBFB69268CEA7DB0B1374DF52E748293@in.WebX.maYIadrTaRb...
> Larry, looks like you accomplished this feat in both instances by setting
> the bend radius to a very small number. I have contemplated the same thing
> to achieve a desired result as well, but rejected it because I feared it
> would result in an inaccurate flat pattern. Is this the case do you know?
> Have a nice day
> "Larry Caldwell" wrote in message
> news:51880AFD8FA9F693CFE73D8B3EE59BDD@in.WebX.maYIadrTaRb...
> > I put a couple of files in iCF; 2 files; one with a small remnant left.
> Not
> > sure it's what you're after, but I think it could be made okay.
> > ~Larry
> > "RuiF" wrote in message
> > news:5CA8ABB21F526B64332EFCCB4DD0FE1F@in.WebX.maYIadrTaRb...
> > > Hi all
> > > I'm sure someone posted a method of doing what I want, but I can't
find
> it
> > > in older messages.
> > > What I need is a flange as in the darker part, with no rip relief as
I'm
> > > getting in the lighter one.
> > > I created the darker one by offsetting a plane then creating a flat
wall
> > and
> > > finally a bend.
> > > I'm sure someone posted the sheetmetal settings that did this with a
> > normal
> > > flange feature.
> > > Anyone?.....
> > > Thanks
> > > Rui
