I created a sheet metal part using two sketch planes and then joined the two faces together using the "bend" tool. The problem I an having is that I need one radius in the part to be one value and the other radius to be another?
Is there anyway to do this?
Not with the bend tool. You just have to model it a different way.. contour flange/cut,etc...
But...making them the same "could" save you a bit of money in setup cost.
Hi Kevin,
Seems pretty straight forward to me... Please see the attached file. IV2010 format.
Cheers,
Igor.
