Inventor Forum
Sheetmetal Pipe coping template
7 REPLIES 7
Message 1 of 8
autorestorer
837 Views, 7 Replies
l am trying to create a coping template for a pipe to pipe cope. I started with pipe from the Component library then converted it to a sheetmetal part, next I created a rip through the pipe wall. When I try to unfold the pipe it appears that all the edges are being unfolded. I have tried many different ways to do this but the results are pretty much the same.
Any help would be appreciated.
7 REPLIES 7
Message 2 of 8
JDMather
in reply to: autorestorer
An assembly file (*.iam) is only a list of hyperlinks to the part files (*.ipt) and a record of assembly constraints (and a bit more).
You must include the part files.
Message 3 of 8
autorestorer
in reply to: JDMather
Thanks this is the first time I try to post anything, hopefully this is correct.
Message 4 of 8
JDMather
Your Rip feature does not go all the way through the part?
Message 5 of 8
JDMather
Since the coped edge is not perpendicular to the flat - might have to help Inventor out a bit (see attached).
Message 6 of 8
autorestorer
This is exactly what I was trying to do, can you explain how you were able to get the RIP to go all the way through? I am new to inventor and trying to learn as I go. I have a few others I need to do similar to this, I have one coping pipe coping to a pipe cap, and I am having the same trouble. I would appreciate the help.
Thanks for the response.
Message 7 of 8
JDMather
You should be able to "reverse-engineer" my example.
Examine the feature tree.  What do you see different?
Message 8 of 8
autorestorer
I want to thank you, this method works great. I have created multiple parts using your suggestion, and it worked flawlessly.
Thanks again
