Inventor Forum
Sheetmetal Loft?
4 REPLIES 4
209 Views, 4 Replies
Sheetmetal Loft?
Is there a way to create a sheetmetal loft? We need to make features that are essentially contour flanges between two different sections.
-Thanks much.
-Matt
4 REPLIES 4
yes and no
yes you can make a loft between the two sections
but the thickness will not be quite the same.  if you draw two sketches --
both a line - loft between the two and then thicken the thickness will be
right.  no -- you cannot flatten it.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Is
-Thanks much.
-Matt
You can flatten it with
href="http://www.spi.de/index_e.htm">SPI Sheetmetal Inventor 5.3
(though the
version doesn't work with Inventor 6 - new version coming out
shortly).
yes and no
-- both a line - loft between the two and then thicken the thickness will be
Is
-Thanks
much.
-Matt
You can also Loft between two or more filled
sections and then Shell to the desired thickness.  This is the method that
must be used to unfold "freeform" models in SPI.
yes and no
Is
-Thanks
much.
-Matt
Does anybody know if a feature like this is planned in the future? In ProE it was a sheetmetal blend and we used it heavily.
