I am trying to create a 3d model from an existing flat pattern of a Sheetmetal shape. I have tried by folding on the bend lines etc. I cannot seem to get it to work and was wondering if others could advise on if it is possible.
The shape is a square to round breech only a half flat pattern of one end see the attached ipt file of what I have so far. I want to bend the sheet on the sketch lines but I keep getting errors.
Any help is much appreciated.
It is almost always better to model the finished form and let Inventor generate your flat pattern.
What are the end-goal dimensions?
Use Lofted Flange.
I did not see any dimensions on your sketch?
I have tried to model the required shape but am having trouble with the transition. If someone could please have a look and suggest a solution I would appreciate your help.
See the attached ipt file for my attempt.
Jack
Hi! In end of the modeling, do you expect each lofted flange to be a separate sheet metal part? Or, you want them to be flattened as one sheet?
Thanks!
I understand what you mean, however the way ive done it, it shouldnt matter. I am looking for a solution for the breech section.
Any suggestions would be great.
Jack
Hi Carlos,
I understand what you are saying. I guess I didnt explain clearly. I am not fussed about the branch pipes, im only trying to get the breech part developed, even just one of them(even a half section only). I cant seem to get the loft to happen. From what I have researched I believe thats its due to the spline shape that I am trying to loft to.
As I understand the sheetmetal loft tool cant loft to 3d sketches or splines. I belive this is the issue but I am not sure... thanks for your time.
If anyone can advise or confirm?
Jack
I think your original art might be flawed.
Can you model as solid model (forget wall thickness and sheet metal for now).
I can see two different solutions - and I am not sure which one you are after.
A solid model will clear that up for me.
Hi JD,
Thanks for the reply,
I cant seem to get the solid loft either. I have attached my attemp to show the shape that I am after. I think this should clarify what im after.
Please let me know if not clear.
Jack
This end would not be circular.
A cylinder cut at an angle is not a circle.
I still cannot produce a sheetmetal loft for the geometry. Does anyone know why? Is it the spline shape? I am lost.
Attached is my attempt to model the transition piece. I can not open your file, so I have based my design on the picture you have provided earlier. The model still need some work on it to get the flat pattern correct, but it should give you some ideas, I hope.
Cheers,
Igor.
@mrjackg wrote:I still cannot produce a sheetmetal loft for the geometry. Does anyone know why? Is it the spline shape? I am lost.
