Inventor doesn't like a 0-gap and most likely will throw up an error. something like 0.00001 will get you close. If not, then convet it to a weldment and use the Gap-Weld to close it up. Will need to create a new IAM to do the weldment.
So where do we find the value to set the default "Miter Gap"? It is not located under "Sheet Metal Unfold" as help desk search suggests. I can see it in the parameters of the default template (set to thickness), but it is greyed out. A default value of .01" is much more common in our parts.
