Inventor Forum
Sheet Metal
17 REPLIES 17
Message 1 of 18
sergej_dezelak
793 Views, 17 Replies
Sheet Metal
I have problem with sheet metal.
In attachment is sketch, that I need and Flat Pattern. The problem is that I need at the end Perpendicular rectangle of this plate. So the flanges should be angled or tapered. Is that posible to do in sheet metal?
17 REPLIES 17
Message 2 of 18
JDMather
in reply to: sergej_dezelak
@sergej_dezelak wrote:
... Is that posible to do in sheet metal?
Yes.
Message 3 of 18
sergej_dezelak
in reply to: JDMather
JDMather thanks for fast response.
But how? I have no idea.
Message 4 of 18
JDMather
Attach your *.ipt file here.
As it is now, I have no idea what version of Inventor you are using.
Message 5 of 18
sergej_dezelak
I am using Inventor Professional 2015.
Here is the ipt
Message 6 of 18
JDMather
Here is one possible solution.
Probably an infinite number of solutions - depending on what you really want.
Message 7 of 18
sergej_dezelak
No that is not what I need.
I need what I have already, but only Flat Pattern need to be correct rectangle, where it is bend it has to be angled.
Message 8 of 18
JDMather
... but only Flat Pattern need to be correct ...
Flat pattern is correct for the part you modeled?
Message 9 of 18
sergej_dezelak
No Flat pattern is not correct. Outer shape it should be perpendicular rectangle.
Message 10 of 18
Uziemblo_U
Sergiej,
on rectangular sheet metal draw a folding line,
and use command "Fold" (twice)
uu
Message 11 of 18
sergej_dezelak
in reply to: Uziemblo_U
Uziemblo_U,
If I will use fold than when I make Flat Pattern it will stil not be a rectangle ant the end.
Message 12 of 18
JDMather
Something like this?
Message 13 of 18
Uziemblo_U
"Fold" command do not add or remove material
your first base rectangle is your flat pattern
you only folding sides
uu
Message 14 of 18
sergej_dezelak
I need something like this at the end when I create Flat Pattern. I draw this in AutoCAD.
I think this with Lofted Flange could be a solution.
Uziemblo_U,
I am not sure that this is possible with using Fold command.
Message 15 of 18
JDMather
Note that the Lofted Flange flat pattern is not perfect rectangle, but I was too lazy to bother with Fold since it looked close enough for sheet metal tolerance for me.  But Fold should work as well.
Message 16 of 18
Uziemblo_U
Sergej,
it is exactly what I said,
1. Draw base rectangle of your flat pattern
2. Draw first folding line exit skech and "fold"
3. Draw second line and fold....
uu..
Message 17 of 18
sergej_dezelak
Yes Fold is the best option, I try it and its working.
Thanks for the solution.
Message 18 of 18
Uziemblo_U
Attached is a file
