Inventor Forum
sheet metal
4 REPLIES 4
413 Views, 4 Replies
sheet metal
Can this part be made with sheet metal tools...it will be made from aluminium..
i attach the shape made with standard tools and the sheet metal attempt.......how do add the sides in sheet metal
Regards
Terry
Inv-2013
4 REPLIES 4
JDMather
Here is a quick example.  (you didn't have any bends or rips (corner seams)), so it was hard to tell what you are after, this might get you started)
You might have to alter your design a bit.
That is a good starting point for  me.Thanks
How would you cut 4 slots across by 6 slots down.Slot size would be 2mm x 4mm
How would you cut out the slots ?
JDMather
What slots?
I didn't see any in your files.
Project Flat Pattern and Cut Across Bend
or
Unfold, Cut, Refold.
in reply to: JDMather
