hi.
How Can I Make Flat Pattern From A Part Of Cylinder ? (2013 Version)
Like Attached Image.
Best Regard
Convert the model to Sheet Metal, make sure that the active Sheet Metal Rule matches the thickness of the part exactly, and it should be able to create a flat pattern. If you have any trouble with it, post the part and someone here may be able to show you how, or figure out what you're doing wrong.
