Inventor Forum
Sheet Metal Unfold Rule
6 REPLIES 6
611 Views, 6 Replies
When Using Sheet Metal, in the Sheet Metal Defaults how do i know which Unfold Rule to use?
When do i use "Default_Kfactor" and when do i use "BendCompensation"?
Are there set thickness's where i will use the one and not the other?
As ive noticed that there is a diference to the unfold flat pattern when using either one.
6 REPLIES 6
JDMather
These are experienced based settings.
Do you make these parts on-site, or do you send the design to someone else to manufacture?
in reply to: JDMather
The designs are to be sent off for other companies to manufacture.
Good Day Sr.
I am in a bit of trouble with an assembly and for what I´ve seen, you´re quite the Guru on Inventor so I plea for your help and knowlege.  My problem is as follows:
Is there a way to do rod design just like in sheet metal? I am trying to assemble a bottle rack, these product looks like a dish dryer like the ones moms have next to the kitchen sink, so they can air dry, I am attaching a picture of the example not the product in fact, but it is simmilar in the metal part, with bent rods and such.
My problem is not modeling each part, I can extrude them or make a sweep, but when I try to assemble them, due to tangents and distances I can´t assemble them the way I want them to. I would really appreciate if you had any tips on how to do these kind of assemblies, becaus it´s really becoming a pain in... well... everywhere hehehehe.
Sorry to bother you and please excuse my poor english since it is not my first language.
Thank you and hope to hear from you soon.
Kind Regards,
Marco
Hi Marco
Try creating working planes in each part, offset the planes with the distances you would like the parts to be constrained from other parts, then constrain the parts together using the working planes.
Hope you come right
JDMather
Unless you work very very very closely with these companies - I recommend that you DO NOT specify the flat pattern.
Give them only the finished dimensions of the folded part - and they will determine the bend allowances they need for their machinery to properly bend to the finished dimensions.
JDMather
@Anonymous wrote:
Good Day Sr.
I am in a bit of trouble with an assembly ...
Different problem - start a new thread.
