k factors are also different depending on the press brake and the pressure/die type.
what works on our press brake will not work on others with the same material and same bend radius.
I once found a GREAT excel formula for calculating the k factor for each press brake but cant seem to locate it again.
but here is the kfactor that we use for .125 copper with a .032 bend radius kfactor=.340
press brake is a guifil (essay int.) just for anyones info
