Inventor Forum
Sheet Metal Thickness in Drawings
2 REPLIES 2
luis_andueza
265 Views, 2 Replies
Hi everybody,
Is there a way to put the Thicness of Sheet Metal parts in drawings part lists automatically? using Inv 2008.
Luis José Andueza Castro
Ing. Mecánico - Consultor CAD/CAM/CAE/Data Management
www.dimcad3d.com | LinkedIn |
¿Te resultó útil esta publicación? No dudes en darle Me gusta a esta publicación.
¿Tu pregunta fue respondida exitosamente? Entonces haz clic en el botón ACEPTAR SOLUCIÓN.
2 REPLIES 2
in reply to: luis_andueza
Yes, create a new material style using the "Style and Standard Editor..."
under "Format" on the main menu with an ipt open. Include in the material
description, the thickness. For example, call it CRS .06 (16ga).
Next edit your Sheet Metal styles to use newly created material, plug in
your k factor etc.
Now in your idw template, edit your parts list style to add a column for
"Material".
That should do it. See zip file for some screen shots, could not post
unzipped.
Howard Delano
Design Engineer
Stainless Design Concepts
A Division of CVD Equipment Corporation
1117 Kings Highway
Saugerties, NY 12477
Website: http://www.stainlessdesign.com
wrote in message news:5627130@discussion.autodesk.com...
Hi everybody,
Very easy. If you create a new sheet metal part, then go to Tools >
Parameters, you will find a parameter already created. Check the export box
at the end of the line.
Then in Styles, create a parts list with the extra column.
Dennis Jeffrey, AICE, MICE
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP2, AIP 2008
HP Pavillion Zv5000 (Modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://www.design-excellence.com
Hi everybody,
