Can somebody take a look at the picture attached and tell me whats the best way to make tabs on a rolled round ring. I got it done using unfold/refold option but I can not get sheet metal flat.
Let me know if there is a good method for getting this done.
Thank You
Regards
William
Solved by JDMather. Go to Solution.
Maybe something like this?
You never stated what version of Inventor you are using.
how to join that gab ? weld ? rivet ? or there is another options ?
if you don't mind please list all method u know.
thank you very much
Can you post more of a detailed explanation as to how you made that part?
I am a sheet metal novice for sure, and am not entirely sure how you made that part. That is exactly what I am working on currently and getting nowhere fast.
EZW
@Anonymous wrote:
...That is exactly what I am working on currently and getting nowhere fast....
Q1. What version of Inventor?
Q2. Can you attach your *.ipt attempt here?
Inventor 2016 | .ipt attached.
I have tried unfold and refold. I have tried a few other things. In the end, I was hoping for something clean and that shows up in the flat pattern.
I am hoping to get the tabs 120 degrees apart with slotted 5/16" clearance holes on a 85mm bolt circle.
EZW
The part you attached is very different than the example in this thread.
I'm not trying to be difficult. The part I am trying to make looks very much like what you gave as the answer to OP. The differences are only a result my own inexperience with sheet metal and how to go about making a part as such in Inventor.
I don't know what I did 5 years ago - I think I must have fudged, but nobody called me out on it.
