Inventor Forum
Sheet metal, slots, general inquiry
20 REPLIES 20
Message 1 of 21
826 Views, 20 Replies
I am new to inventor. Recently I began a sudy of Mastering Autodesk Inventor and have made much progress in the last few weeks. However, I am stuck on a few problems. Firstly, the  component in question is attached. To create this I drew a spline and revolved it. I converted the object into sheet metal than created a plane above, sketched the slots and  projected them onto the object. After this I used the cut command. Is this a good method or is their an easier way to cut the slots? Now, I am eventually going to prototype this component so I am trying to think as many steps ahead as possible. I think to make this it would be best to draw and cut all the features (i.e slots) on a flat sheet of material than press this sheet into the meandering form. Is it posible to do this in inventor?
I am grateful for any guidance.
Jordan
20 REPLIES 20
Message 2 of 21
The_Angry_Elf
You might want to look into the Punch command in Sheet Metal.
As minor as it might seem, you want to be sure the cut direction is perpendicular to the face you are cutting, otherwise you'll have "slanted" cuts and that could cause fit issues if that's an issue at all.
Make sure the part will flatten as well.
Cheers,
Jim O'Flaherty
Owner - Celtic Design Services, LLC - cdscad.com - An Autodesk Service Partner
We are available for hire. Please DM me or visit our website
Autodesk Inventor Certified Professional * Autodesk Certified Instructor * Autodesk Expert Elite * AU Speaker 2015 through 2022 * AU Speaker Mentor
"Mr. O'Flaherty, never go into small computers. There's no future in them" - Dr. C.S. Choi circa 1984
Message 3 of 21
JDMather
@Anonymous wrote:
.... Is it possible to do this in inventor?
No.
Message 4 of 21
in reply to: JDMather
Is it possible to do this in any other Autodesk program?
Message 5 of 21
JDMather
Modeling the finished part is easy in Inventor.
But deforming a flat or forming flat from deformed (of that design) is not possible in Inventor.
If you need help modeling the finished part - attach your *.ipt file here.
Message 6 of 21
in reply to: The_Angry_Elf
Hi Jim,
It would be far to diffucult to cut the slots parallel to the surface since it's a sine wave. The material will be thin however. But, I tried to punch with no luck. Here's what I tried. First, I projected the sketch of the slots onto the surface than selected punch but got an error mesage saying "sketches placed on a work plane are invalid for this feature." Any idea how I could punch these slots into the membrane? If its not possible that's fine since I'm happy with the cut and can always fillet if need be.
Also, the part does flatten.
Thanks again for your help.
Jordan
Message 7 of 21
JDMather
Attach your *.ipt file here.
Message 8 of 21
Here is the ipt. file. The slots are already cut into r2.  I'd like to learn how to punch these slots from the projection if possible. I'm thinking a press die would cut the slots parallel to the surface but I don't know since I haven't contacted any manufactures to learn how this part would be made. Another issue. Notice in r2 there is a 3d sketch called Cover_plate. What I need to do is create a cover that follows the tappered slots. The rought arc projection at the top of the slots represents the path the cover plate will follow.  I'm not sure how it will fasten to the body by think welding or if I use plastic than some type of glue or ultrasonic weld. Anyway, I am just experimenting and the cover plate is the issue I am currently struggling to design. Any pointers would be appreciated.
Slowly learning. Thanks for your help, again.
Jordan
Message 9 of 21
JDMather
I do not see a Flat Pattern in the file you attached.
...and, have you installed all Service Packs for your version of Inventor?
Message 10 of 21
I had to remove several features in order to attach the file.
Message 11 of 21
JDMather
Find the red End of Part marker at the bottom of the browser.
Drag the red EOP to the top of the feature tree hiding all features.
Save the file with the red EOP in a rolled up state.
Right click on the filename and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
or
if still too large - upload it to Autodesk 360 and provide download url here.
Message 12 of 21
I'm not sure about the service packs but will check. Preparing my file for upload at the moment.
Message 13 of 21
I don't know 360 that well so let me know if this url works. I can share but
I need an address.
https://360.autodesk.com/#/Item/Details?id=6b032e8b980c45a6945579ecdc289dbd&
itemtype=File&tab=Default
Message 14 of 21
Hey JD,
Were you able to access my file via the Autodesk 360 link? I have this strange problem. When viewing the membrane from afar there is a deformation in the last ripple. See image attached. It's not a big problem since I will be rebuliding this component but I wonder why this deformation appears. When I zoom in, it dissapears?
Jordan
Message 15 of 21
JDMather
@Anonymous wrote:
Hey JD,
Jordan
No.  It is always a good idea to try the url yourself after posting.
That does not appear to be a proper download link.
Try these steps, click on the page Actions -
The url should look similar to this one.
In the image you posted that could be a graphics anomaly - try exporting as STEP an translating back in and see if it is still there.
Message 16 of 21
A360 link https://myhub.autodesk360.com/ue29e652f/shares/public/SHabee1QT1a327cf2b7a623bd9d7dce97011
Password is MMembrane
I converted the file into STEP than back but anomily still there.
Message 17 of 21
If I delete 'Slot_r4_projection' the anomoly dissappears.
Jordan
Message 18 of 21
JDMather
Jordan
Can you post a screen shot of your flattened "Flat Pattern"?
I still do not get a correct flat pattern from the file you uploaded to A360.
Message 19 of 21
Screen shot of flat pattern as requested. I re-uploaded the file.
Message 20 of 21
JDMather
How is that a "flat" pattern?
Isn't a flat a planar object?
If this was my part I would figure out some clever way to use a Feature Pattern rather than all of that sketching.
But I haven't spent any time trying to figure out exaclty what that "clever way" might be since early on I indicated to you that you will never flatten this part (at least correctly) in Inventor.
Then you indicated that you have a flat pattern - but the image you posted is clearly not flat?
