I make the part using sheet metal tools.Underneath the part i used solid model tools.Is there any issues with using both Sheet Metal tools and Solid Model Tools in the same part?
The next question is can the shapes made with Extrusion 2 be made from Sheet Metal Tools.I used Sheet Metal Loft but not sure it was correct so used Extrusion instead
Can Extrusion 2 be shelled out with 3mm thickness if solid model option used?
Solved by blair. Go to Solution.
I think I would use the Punch tool to create those additional features. (unless you aren't worried about getting Flat Pattern)
No not worried about flat pattern...what would you do if not using flat pattern
How would you use the punch tool.Would i need to make custom punch for those sizes and would you place the centre point in the curve shape?
That is interesting as never thought of the punch tool
I think creating a Punch for this would be overkill unless you would re-use it over and over again.
I have other work to do, but I will try to come back to this later today if you don't get some good results.
Do you haveor see any issues with using both Solid Modelling Technique and Sheet Metal Tools in the same part.Use both techniques to create a part.
I could get the shape with Extrusion 2 but not with Shett Metal Tools
Thanks again
Hi Blair
Thank you
If i choose sheet metal how would i get the same affect as Extrusion 2 (solid modelling) using sheet metal tools?
James
