Inventor Forum
sheet metal shell
7 REPLIES 7
Message 1 of 8
James__S
716 Views, 7 Replies
sheet metal shell
I make the part using sheet metal tools.Underneath the part i used solid model tools.Is there any issues with using both Sheet Metal tools and Solid Model Tools in the same part?
The next question is can the shapes made with Extrusion 2 be made from Sheet Metal Tools.I used Sheet Metal Loft but not sure it was correct so used Extrusion instead
Can Extrusion 2 be shelled out with 3mm thickness if solid model option used?
7 REPLIES 7
Message 2 of 8
JDMather
in reply to: James__S
I think I would use the Punch tool to create those additional features.  (unless you aren't worried about getting Flat Pattern)
Message 3 of 8
James__S
in reply to: JDMather
No not worried about flat pattern...what would you do if not using flat pattern
How would you use the punch tool.Would i need to make custom punch for those sizes and would you place the centre point in the curve shape?
That is interesting as never thought of the punch tool
Message 4 of 8
JDMather
I think creating a Punch for this would be overkill unless you would re-use it over and over again.
I have other work to do, but I will try to come back to this later today if you don't get some good results.
Message 5 of 8
James__S
Do you haveor see any issues with using both Solid Modelling Technique and Sheet Metal Tools in the same part.Use both techniques to create a part.
I could get the shape with Extrusion 2 but not with Shett Metal Tools
Thanks again
Message 6 of 8
blair
A while back I did see an issue when using the either the Hole or Cut command. One of the Solid features didn't translate through to the Flat Pattern. It was a few releases ago but it did happen. ADSK recommended to use the Solid tools for Solid parts and use the Sheet-Metal Tools for Sheet-Metal parts. Maybe now it's been corrected but after spending a couple of days making corrections I don't cross the two.
Delta Tau Chi ΔΤΧ
Message 7 of 8
James__S
in reply to: blair
Hi Blair
Thank you
If i choose sheet metal how would i get the same affect as Extrusion 2 (solid modelling) using sheet metal tools?
James
Message 8 of 8
blair
As JD posted, I would use the Punch Tool, or create a IAM and add these parts (features) as separate parts. Doing it this way won't allow the item to "Flatten" as the thickness is not uniform, which is the only reason that you would use the Sheet-Metal module.
Delta Tau Chi ΔΤΧ
