Inventor Forum
Sheet metal - Refold
2 REPLIES 2
Henrik_Lo
260 Views, 2 Replies
HI
Why can’t I fold the hole pattern, I need this for making a solid model from the tube.
Regards
Henrik
2 REPLIES 2
-niels-
in reply to: Henrik_Lo
Refold can't (or won't) refold unattached sections, the remaining bits of your cut are floating in space and no longer attached to the original geometry.
If you want to cut this from your cilinder shape, you could try using emboss with "wrap to face".
I've attached an example, i didn't fix the sketch after redefining it to the new workplane so please take the time to recreate it properly.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Henrik_Lo
in reply to: -niels-
HI
Thangs for replying, yea, that will give med the result I am after too, this must be the way to go.
Regards
Henrik
