When I try to face projected geometry, it displays the part correctly, but when 'apply' or 'ok' are selected, inventor states that there is an issue and the function fails.
I managed to get it to work by turning the projected geometry into construction lines and tracing over. However, this is tedious and I'm sure there is a better way. I also tried to extrude the projection, and though that worked, flanges could not be added to the extrusion.
Using Inventor 2013 Pro
File description:
Thank you.
Solved by Yijiang.Cai. Go to Solution.
When looking in the sketch, the sketch geometry is imported from non-native Inventor file. When checking the type of sketch geometries, there are many splines but not lines or arcs.
When creating face using this sketch profile, the preview does work fine, but it fails. When break link for the imported sketch, then creating face, it works fine. But the downstream features like flange can't be added as the edge of face is not linear but spline. Just like we could create extrude using the sketch profile but can't add flanges.
When tracing over the imported sketch, it looks that you use the lines and arcs for the new sketch. And the flanges can be added after face created. Currently Inventor does not support to add flange based on the non-linear edge.
