Inventor General Discussion
Valued Contributor
0 Kudos
Post 1 of 9
sheet metal part
286 Views, 8 Replies
12-20-2012 05:49 AM
Hi
How do i make the attach file as a sheet metal part?It takes a lot of  moves to make as solid part..can it be made in sheet metal?
Regards
Simon
Yup, looks good except sketch8 needs to be fully constrained.
Valued Mentor
95 Kudos
Post 2 of 9
Re: sheet metal part
12-20-2012 06:19 AM in reply to: simon_toaldo
You should be able to make this as a sheetmetal part. Start in the sheetmetal environment and instead of using extrude as your first feature, use the face tool. Instead of extrusion 2, use a cut. You could also use the face tool with the bend option to replace extrusions 5 & 6. Give it a try. When you get stuck, post what you've accomplished here and someone will help you out.
Peace,
Jeff
Inventor 2013
Valued Contributor
0 Kudos
Post 3 of 9
12-21-2012 03:01 AM in reply to: simon_toaldo
I got to this point to sheet metal part.What steps should i now take to complete the rest of the part?
I am not sure how to create the sections which are bent
Appreciated
Valued Mentor
95 Kudos
Post 4 of 9
12-21-2012 04:46 AM in reply to: simon_toaldo
Take a look at the attached file. It may give you some ideas.
Peace,
Jeff
Inventor 2013
Valued Contributor
0 Kudos
Post 5 of 9
12-21-2012 05:13 AM in reply to: simon_toaldo
Thank you,
Through your technique i made the next step but need help adding the last part to this.
CAn this when finished be flattened
Appreciated your help
Valued Mentor
95 Kudos
Post 6 of 9
12-21-2012 05:29 AM in reply to: simon_toaldo
It will if you can keep the top of face4 straight. See the attached file.
Peace,
Jeff
Inventor 2013
Valued Contributor
0 Kudos
Post 7 of 9
12-21-2012 05:42 AM in reply to: simon_toaldo
I added the last piece.Is this how you would have added this curved piece?
Thank you
Valued Mentor
95 Kudos
Post 8 of 9
12-21-2012 05:51 AM in reply to: simon_toaldo
Peace,
Jeff
Inventor 2013
Valued Contributor
0 Kudos
Post 9 of 9
12-21-2012 05:54 AM in reply to: simon_toaldo
Thanks for your help Jeff
Merry Christmas
