Hi
How do i make the attach file as a sheet metal part?It takes a lot of moves to make as solid part..can it be made in sheet metal?
Regards
Simon
Solved by japike. Go to Solution.
You should be able to make this as a sheetmetal part. Start in the sheetmetal environment and instead of using extrude as your first feature, use the face tool. Instead of extrusion 2, use a cut. You could also use the face tool with the bend option to replace extrusions 5 & 6. Give it a try. When you get stuck, post what you've accomplished here and someone will help you out.
I got to this point to sheet metal part.What steps should i now take to complete the rest of the part?
I am not sure how to create the sections which are bent
Appreciated
Take a look at the attached file. It may give you some ideas.
Thank you,
Through your technique i made the next step but need help adding the last part to this.
CAn this when finished be flattened
Appreciated your help
It will if you can keep the top of face4 straight. See the attached file.
I added the last piece.Is this how you would have added this curved piece?
Thank you
Yup, looks good except sketch8 needs to be fully constrained.
