Need help - sheet metal part can not create flat pattern. - Inventor 2012
See attached inventor part file.
Solved by JDMather. Go to Solution.
Your part flattens fine in r2015.
Have you installed all Service Packs for your release of Inventor?
After installing the Service Packs, it might also help to pre-select the face before clicking Flat Pattern (this might just be superstition, but I seem to recall at some time back that often solved the problem).
