I created this part in a flat then used Bend Part to roll into a circle.
Converted to a sheet metal & used fold to bend tabs.
I'm can't seem to get a correct Flat Pattern.
I'm kind of new to sheet metal (the easy stuff I can do most of the time).
I was wondering if some one could tell me were I went wrong or if I'm wrong from the start.
Attached is what I have tried.
Thanks in advance for any help.
Solved by JDMather. Go to Solution.
I don't think you can do that in r2012, and I have doubts about later releases (when was Contour Roll added).
In general, stick with the sheet metal tools as a beginner (no Extrude, use Face instead, no Bend Part, use Fold instead (and only if there is no other way).
JD,
Thanks I will take your advice and stick with sheet metal tools.
Should I draw it as the finished part & split to get the flat pattern,
or draw it as flat and fold 360 degree. (if fold will do that).
I don't think it is possible in r2012. (I could be wrong.) But the general rule is to always model sheet metal in the final form (use Unfold/Refold rather than Fold if needed).
JD,
I have a Contour Roll Command.
I will give it a try.
Thanks.
@pbrooke wrote:
JD,
I couldn't remember when it was added - I didn't think it went back that far.
In that case - a very similar problem has come up here in the past 6 months (at least twice).
Hopefully that person will see this thread (I have no idea on what to search for (other than Contour Roll)).
