Hi to all,
that's my problem.
Inventor interprets the maximum Length and Width of the flat pattern depending on its orientation.
I can change that using "Edit Flat Pattern Definition". But one by one.
But if i want to automate the process, using part list in drawing already filled with thickness x length x width of the flat pattern, is there a strategy to avoid control and checking each sheet metal part orientation one by one to obtain the correct max measures of the sheet metal "rectangle? iLogic?
Thank you
