Inventor General Discussion
Active Member
Nameless337
Message 1 of 7 (518 Views)
Sheet Metal Nesting
518 Views, 6 Replies
07-15-2013 09:39 AM
My company does a lot of work with sheet metal using a shear and turret punch. I'm working on nesting some of our smaller parts so that the turret punch can do multiple pieces at once out of the same sheet and then send the sheet to the shear to be cut down into individual pieces. I haven't been able to find a good way to create the punch drawings necesary for these nested parts.
Currently my workaround is to take the part I want to nest and use the sheet metal unfold feature on it to flatten it out. I then save the unfolded piece as a copy which I use exclusively for nesting. Then I make an assembly out of this flat copy, using the assembly pattern feature to create a nested assembly used for the drawing. The problem with this is that there are now two unlinked versions of the part: a flat one for the nested drawing and a formed one for the final 3D model.
Has anyone found a better way to do this? I'm surprised inventor doesn't have something for sheet metal nesting built in, but failing that is there any way to use the flat pattern representation of a sheet metal part in an assembly without breaking the link?
I do something similar using a similar work flow to you.
I use the derive command to make a live updating copy of the "folded version" and then apply an unfold feature to create an always flat model. The key here is to make sure that the "Thickness" parameter in the derived part matches the "Thickness" of the original model.
Hi Nameless337,
There is a user submitted idea in the IdeaStation for this functionality to be added to Inventor in the future. You might take a moment to give this a vote:
http://forums.autodesk.com/t5/Inventor-IdeaStation/Nesting-for-2D-outlines/idi-p/3922988
There is also another 3rd party add-in listed at the IdeaStation link.
I hope this helps.
Curtis
mrattray
Message 2 of 7 (503 Views)
Re: Sheet Metal Nesting
07-15-2013 10:43 AM in reply to: Nameless337
Mike (not Matt) Rattray
blair
Message 3 of 7 (479 Views)
07-15-2013 02:12 PM in reply to: Nameless337
Not directly in Inventor, we use a 3rd party software called Radan for our profiling/nesting. Other software such as Striker, Sigmanest and MTC (now Thermadyne).
Radan handle both punching as well as profile cutting (not cheap). It does allow for common-line cutting and advanced nesting capabilities.
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 344.60
SpacePilot Pro 3.06.109
Delta Tau Chi ΔΤΧ
Curtis_Waguespack
Message 4 of 7 (467 Views)
07-15-2013 02:59 PM in reply to: Nameless337
Hi Nameless337,
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Active Member
Nameless337
Message 5 of 7 (423 Views)
07-16-2013 08:20 AM in reply to: mrattray
Thanks a lot. Using a derived part for the nesting will go a long way toward keeping everything linked. One more thing has come up though and I'm hoping you've found a workaround for it too. When I use the derived flat part to make a nested assembly I have to enter the component pattern spacing manually. Is there a way to reference a dimension in the component as the spacing for an assembly pattern so taht it will update automatically?
New Member
Gary_CC
Message 6 of 7 (103 Views)
07-15-2014 11:46 AM in reply to: blair
You could look at Metamation as well, they have some pretty good solutions and have always done a good job for me in the past.
mcgyvr
Message 7 of 7 (96 Views)
07-15-2014 12:09 PM in reply to: Nameless337
IMO sheet metal nesting should ALWAYS be done as part of the punch programmers job and in nesting specific software..
I sure wouldn't want that in Inventor..
I thought the software for all punch machines had that functionality built in.
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
