Inventor Forum
Sheet metal model
1 REPLY 1
ortem
205 Views, 1 Reply
Sheet metal model
Hi Guys n Gals,
I'm new to Inventor 2015 and have been trying to learn it since June this year. I'm doing ok but got a bit stumped when trying to produce a model (see attached jpeg). The method I used was to start with a solid block, then shape it to the correct size and the shell it and finally cut the apertures out. This was fine until I wanted to convert it to sheet metal and cut it into separate parts for laser cutting.
I.e. The top was one solid piece which consisted of a square base with triangular sections on the sides to be folded. This was repeated for the base. The two seperate parts were to be connected with struts forming a lantern.
Can anyone tell me how I should go about modelling this? Keep in mind that I possibly need to change the overal sizes via the parameters table if the client changes their mind and also I need to get it laser cut from dxf files.
Cheers in advance,
V
1 REPLY 1
in reply to: ortem
files converted to sheet metal works OK only when universal wall thickness applied. if variety of thickness try to draw it as part with few solids depending on material thickness then create separate part from each solid, this new files convert to sheet-metal parts and specify the thickness in each.
