Inventor General Discussion
Valued Contributor
dominiekvanwest
Message 1 of 5 (247 Views)
Sheet metal material not correct
247 Views, 4 Replies
07-12-2012 03:48 AM
I'm using Inventor 2013. For some reason the material in a sheet metal part is not linked to the Sheet Metal Rule.
In the attachment you see on the left side that the material TRPL5-7 (that's a material I created) is linked to the Sheet Metal Rule TRAANPLAAT_5_7. But if I select TRAANPLAAT_5_7 as Sheet Metal Rule in Sheet Metal Defaults (see right picture in attachment) the Material doesn't change to TRPL5-7.
What's wrong here?
Thanks in advance!
Dominiek
In the sheetmetal defaults tab, change the material to "by sheetmetal rule". That will tell Inventor to use the material specified in the rule, as opposed to the overriding material you have selected.
Employee
xingyuan
Message 2 of 5 (234 Views)
Re: Sheet metal material not correct
07-12-2012 04:40 AM in reply to: dominiekvanwest
Hi Dominiek,
Would you mind upload the attachment?
Sam
[Sam Yuan]
[Sr. Software QA Engineer]
[Alias] Quality Assurance Team
Valued Contributor
dominiekvanwest
Message 3 of 5 (228 Views)
07-12-2012 04:54 AM in reply to: xingyuan
I don't seem to be able to edit my first post, so I'll add the attachment here
mrattray
Message 4 of 5 (221 Views)
07-12-2012 05:01 AM in reply to: dominiekvanwest
Mike (not Matt) Rattray
Valued Contributor
dominiekvanwest
Message 5 of 5 (214 Views)
07-12-2012 05:15 AM in reply to: mrattray
Oh, of course that's the solution. Just looked over it :smileyhappy:
Thank you!
