Inventor Forum
Sheet metal Jog
13 REPLIES 13
Message 1 of 14
2787 Views, 13 Replies
Sheet metal Jog
Hello All,
How can I create a sheet metal jog? Like the attached. I used a contor flange to creat this one, but I have to add a jog to an existing part and don't want to have to totally redraw it just to get the jog. I'm hoping you can add it like you can a flange.
TIA
Rick
13 REPLIES 13
Message 2 of 14
mcgyvr
Just create another face on a workplane and use the bend feature
See attached
Message 3 of 14
JDMather
Not sure what you mean. You do realize you can convert an existing part to sheetmetal. Of course it should have uniform thickness.
Message 4 of 14
madhumatiramesh
If you create a flange with zero degree angle (and "old method" check box checked in Inventor 2008) then it will create a jog. Can you post the existing part?
Madhumati Ramesh
Software Engineer
Message 5 of 14
Rick,
Would Mirror help? If the new jog is symmetric to the original one about a
mirror plane, you can simply mirror the Contour Flange about the plane.
Johnson Shiue
Inventor QA Tech Lead, Autodesk
johnson.shiue@autodesk.com
wrote in message news:5741903@discussion.autodesk.com...
Hello All,
TIA
Rick
Message 6 of 14
cadman777
in reply to: mcgyvr
mcgyver,
Thanks for this work-flow
Worked like a charm for me!
Cheers ... Chris
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 7 of 14
Hi mcgyvr
great! that works well, is it possible to have two different sized faces so the the bend transition from the first full width say 50mm up into the second full with say 100mm wide?
i played with this but the bend width stays the same as the smallest width.
regard Adrian
Message 8 of 14
Adrian,
I didn't use that, b/c I just needed a 'joggle joint' for sheet metal parts to join co-planar.
However, I did look up the help file to make sure I did it right, and it seems that one of their video tutorials shows what you're talking about with like 3 scenarios.
... Chris
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 9 of 14
Hi Chris
Thanks, what did you search for to find these videos or do you have a link?
regards Adrian
Message 10 of 14
cadman777
I discovered a 'joggle joint' can be made using either the "bend" or "face" command in the sheetmetal module.
I used the "face" command for reasons I can't recall.
See the attached screen-shot that I got to by accessing "help" from within the "bend" command.
I haven't tried to do what you want to do, but maybe you can get it to work for you?
... Chris
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 11 of 14
Hi Chris thanks, i have tried these when i was messing about but the bend extension is not working??
I am including a sample file as I hope this gets noticed as a possible bug
I am using inventor 2012, I have tried a double bend and as in this enclosed sample a single bend but i can't seem to get the "bend extension perpendicular to side faces" to work, it always extends to the width of the smallest edge?
is this a bug in 2012?
regards Adrian
Message 12 of 14
Adrian,
I sent you the wong Help file screen shot.
Find attached the correct one.
Turns-out you can't do what you want to do, unless the adjoining sheet you're connecting to has tapered/angled edges.
Cheers ... Chris
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 13 of 14
Adrian,
I have 2010, so can't open your 2012 file.
... Chris
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 14 of 14
Hi Chris
I think this feature should woork on a standard bend as in my sample file, I am sure it is a bug? can anyone verify this?
regards Adrian
