Inventor Forum
SHeet Metal Flat Pattern
13 REPLIES 13
Message 1 of 14
n00kie.tdc
1781 Views, 13 Replies
Hey guys!
I know this was already discussed before, but I am still having issues with creating flat pattern.
I simply don't have this option. All of a sudden everything was working and then all of a sudden I can't make flat patterns anymore. I haven't been changing any options in styles library.
Though when I transfer part into Standard Part and then back to sheet metal it tells me that model has to be uniform thickness equal to model parameter  and that I should set the proper thickness in the Sheet metal Styles match my model. I don't really get it. Why before I didn't have to do anything and now it asks me to to do it ... And I don't really get what I should do ... Can someone help me by explaining what exactly has to be done? Because I tried everything, but it doesn't help ...
Autodesk Inventor 2019
Running on Dell Precision 7720 laptop:
Core i7 6820HQ
16 GB RAM
Quadro P3000
Widnows 7 PRO, 64-bit
13 REPLIES 13
Message 2 of 14
mpatchus
in reply to: n00kie.tdc
Would probably be best to post an example part.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 3 of 14
n00kie.tdc
in reply to: mpatchus
I attached a part.
Core i7 6820HQ
16 GB RAM
Quadro P3000
Message 4 of 14
n00kie.tdc
But it will not show what are my current sheet metal styles are .. like thickness and all unfolding rules ...
Core i7 6820HQ
16 GB RAM
Quadro P3000
Message 5 of 14
mpatchus
Post a snip of your sheet metal style.
Inventor 2025 Beta
Message 6 of 14
-niels-
Your sheetmetal rule is for a thickness of 0.5 while your model is 0.7 mm thick, that is why you are getting the non-uniform thickness warning.
I had no problem creating a flat-pattern in IV2014, with either thickness, so i can't say why you're having problems.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 7 of 14
mpatchus
This is a 2012 part like your signature tag says?
Inventor 2025 Beta
Message 8 of 14
n00kie.tdc
Sorry, it is 2013 file. I upgraded long time ago, forgot to change signature.
Niels, this is not the problem. I mean I tried to change values so thicknesses are the same. It has no effect. I tried to leave mark so that thickness stays as default from Sheet Metal Style... and that still doesn't help.
I created a simple sqare with one side bended and tried to make flat pattern... and i can't, there is no option as create flat pattern... and thicknesses are the same as in SHeet Metal Styles.
Though before I could use another thicknesses, just unmark to use as default thickness from a rule ... but now sheet metal doesn't work at all and that happened just without any reason ...
Core i7 6820HQ
16 GB RAM
Quadro P3000
Message 9 of 14
JDMather
iProperties indicate r2014 SP0, NOT 2013?
I recommend that you first try installing Service Pack 1 and Update 1 for Service Pack 1.
Test and post back the results of the test.
Message 10 of 14
JDMather
@n00kie.tdc wrote:
I created a simple sqare with one side bended and tried to make flat pattern... and i can't, there is no option as create flat pattern... ....
Attach this file here.
Message 11 of 14
rdyson
Are you saying you don't have a Flat Pattern Button?
PDSU 2016
Message 12 of 14
n00kie.tdc
in reply to: JDMather
SORRY GUYS !!!
I got completely lost.... I was extremely busy working on two computers at the same with different Inventor versions....
This issue is on version 2014. I've attached example file earlier in this threat ... and it is from the machine that has this issue, which is 2014.
Core i7 6820HQ
16 GB RAM
Quadro P3000
Message 13 of 14
n00kie.tdc
in reply to: rdyson
rdyson,
I will try it tomorrow! thanks!
Core i7 6820HQ
16 GB RAM
Quadro P3000
Message 14 of 14
n00kie.tdc
in reply to: rdyson
RDYSON,
Thanks! Can't believe I was so stupid not to check that this buttom has just disappeared...
Thank you!
Core i7 6820HQ
16 GB RAM
Quadro P3000
