Inventor General Discussion
Valued Contributor
1 Kudo
Post 1 of 6
Sheet metal/Flat pattern screews up coordinates.
265 Views, 5 Replies
03-15-2012 04:12 AM
Why is it, when I go to Flat Pattern/export to DXF that everything ends up upside down.
I have part where it is important that the correct side is faced upp, (brusched steel).
When i Export it to dxf, it is upside down, and the bruched facefacing down.
2,119 Kudos
Post 2 of 6
Re: Sheet metal/Flat pattern screews up coordinates.
03-15-2012 04:18 AM in reply to: ENRAD
You can flip before exporting.
Attach your file here.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Contributor
1 Kudo
Post 3 of 6
03-15-2012 04:50 AM in reply to: JDMather
Ok, found that, but why cant it be correct from the beginning?
1,701 Kudos
Post 4 of 6
03-15-2012 06:19 AM in reply to: ENRAD
Hi ENRAD,
As JDMather mentioned you can adjust the flat pattern orientation before exporting it as described at this link:
http://inventortrenches.blogspot.com/2011/05/edit-flat-pattern-orientation.html
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Valued Contributor
1 Kudo
Post 5 of 6
03-15-2012 06:41 AM in reply to: Curtis_Waguespack
Yes I understand that, But, if I have say 300 parts to export, thats nearly 1000 extra mouse-clicks to do, so why cant Inventor do it correct in the first place.
Active Contributor
7 Kudos
Post 6 of 6
03-15-2012 06:52 AM in reply to: ENRAD
Pick your face side before you create the flat pattern. You may want to rotate your flat pattern after, but at least your "good" side will be facing you.
Donald L.
Inventor Product Design Suite Premium 2014
Windows 7 Professional - 64 bit
HP h8-1380t - i7-3820 @ 3.6 GHz
10 Gb
AMD Radeon HD7950 3Gb
