I have problem with Save As Command from Flat Pattern in Sheet Metal Mode.
I want to export to DWG file from Flat Pattern to send this layout to our Laser Machine database.
I'm using Inventor 2010 with Vault Manufacturing.
Please describe your problem.
I would save as DXF or as Autocad DWG, in doing this it shuld work fine for you.
You have at least two options from ipt
1. Right click on the Flat Pattern browser node
2. Right click on the Flat Pattern face
(see attached)
I know how to do it. The problem is when I'm doing doesn't work?!
Also I can not check file into Volt.
Yesterday We've got some virus and since then that started to happened.
We cleaned up virus problem but obviously that scew up something with Inventor.
I uninstalled and installed back Inventor 2010 but the problem is still not fixed.
Try a clean uninstall http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14893355&linkID=9242018
then run this http://majorgeeks.com/Windows_Installer_CleanUp_Utility_d4459.html
Make sure anti-virus (including TSR) and UAC are turned off while re-installing.
I am having somewhat of the same problem but was wondering if any of you guys could help me. I can export to a dxf but want to have the bend lines on the dxf/dwg. do any of you guys know how to do that? hope you guys could help
May be this screen shot will give you some ideas...
Igor.
@Anonymous wrote:I am having somewhat of the same problem but was wondering if any of you guys could help me. I can export to a dxf but want to have the bend lines on the dxf/dwg. do any of you guys know how to do that? hope you guys could help
i have a problem of which when i save it, it save the dxf file as the side of the sheet rather the top of sheet. can anyone please tell me how to fix it, thanks in advance
Before export you have to click on the side you want to have on top.
In new releases you can define the A-side.
