Inventor Forum
Sheet Metal Flat Pattern Help..
2 REPLIES 2
prajwal
271 Views, 2 Replies
Hello, I have a part which is to be rolled out of a 0.6250" Plate. I created  surface of the part and thickned it to the correct thickness. But now when I am trying to get flat pattern of the unfolded part inventor is not giving me correct flat pattern. The ipt file is attached.
Any suggessions would be highly appreciated. Thank you.
2 REPLIES 2
JDMather
in reply to: prajwal
See attached file.
prajwal
in reply to: JDMather
Thank you so much. Is there any way the diagonal bend can be removed from the end curves. The length of the curves is flexible.
