Inventor Forum
Sheet metal – Flange to extended side
4 REPLIES 4
Henrik_Lo
2064 Views, 4 Replies
HI
How come I get failure when trying to make this flange, look at picture Sheetmetal1.png
Why is it not possible to make flange in the end, see picture Sheetmetal2.png
Regards
Henrik
4 REPLIES 4
VdVeek
in reply to: Henrik_Lo
Henrik, It's difficult to see what you want by looking at your screen shots. But if i see it correctly, you try to create a self-intersecting bend. Where the new flange intersects with the existing body.
An option is to offset the sides of the new flange. See my screen shot, hope this helps.Flange.JPG
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
Henrik_Lo
in reply to: VdVeek
HI Rob
It worked for my first problem, thanks for quick reply and great help.
Regards
Henrik
johnsonshiue
Henrik,
The reason why the flanges cannot be created on the other end is due to the non-perpendicular detail face there. Most of Inventor sheet metal features operate under the assumption that the side face is always perpendicular to adjacent sheet metal face. If the geometry condition does not support the assumption, the shet metal features will fail to creat. There is a simple trick you can do by using Thicken feature. Please take a look at attached file and let me know if you have any question.
Thanks!
Software Test Engineer
Henrik_Lo
in reply to: johnsonshiue
Hi, I see the trick, thangs for replay, and great help.
Regards
Henrik
