Inventor Forum
Sheet Metal Flange only on partial edge
4 REPLIES 4
9926 Views, 4 Replies
How can I define the length of a flange in a sheet metal part? In other words, I would like a flange to run a definitive length along the edge of a part, not the entire edge of a part.
I apologize if this has been asked before. I did a brief search of the forum and could not find a solution.
4 REPLIES 4
JDMather
Attach your file here.
Expand the dialog box and set Width or desired Offset distance from each end.
elizabethcKTY8W
in reply to: JDMather
Thanks for this post from a long time ago.  Appreciate it - made my life a lot easier today!!
JD you're the best.
rhaefli2
in reply to: elizabethcKTY8W
Hi, I'm trying to do this same thing in Fusion 360 (2020).  (Create a flange that only bends a specified distance on an edge.) Is this possible?
Thank you!
JDMather
in reply to: rhaefli2
See Image.
